Tutorial: Sensores Raspberry + Lovelace
Olá pessoal,
Neste tutorial, vou ensinar vocês a criarem os sensores para monitorar o seu Raspberry e também como configurar o card na interface do seu Lovelace.
Sigam estes passos:
  1. Instalar o HACS
  2. Instalar os addons de Frontend através do HACS
    Mini Graph Card
    horizontal-stack
    button-card
    Bar Card
    Stack In Card
  3. Adicionar os códigos abaixo (configuration e lovelace)
Adicionar o sensor do SpeedTest no /config/configuration.yaml:
# SPEED TEST
speedtestdotnet:
  scan_interval:
    minutes: 60
Adicionar ao /config/configuration.yaml na seção “sensor”:
- platform: systemmonitor
resources:
  - type: disk_free
    arg: /
  - type: disk_use
    arg: /
  - type: disk_use_percent
    arg: /home
  - type: memory_free
  - type: memory_use
  - type: memory_use_percent
  - type: processor_use
  - type: last_boot
  - type: swap_use_percent
  - type: swap_use
  - type: swap_free
  - type: throughput_network_in
    arg: eth0
  - type: throughput_network_out
    arg: eth0
  - type: network_in
    arg: 'Local Area Connection'
  - type: network_in
    arg: eth0
  - type: network_out
    arg: eth0
  - type: ipv4_address
    arg: eth0
  - type: packets_in
    arg: eth0
  - type: packets_out
    arg: eth0
  - type: process
    arg: octave-cli
  - type: load_1m
  - type: load_5m
  - type: load_15m
- platform: command_line
#icon: mdi:lastpass
command: grep -m1 'Home Assistant initialized' home-assistant.log | awk '{ print $6, $7, $8, $9, $10 }'
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(1) }}'
- platform: dnsip
- platform: uptime
unit_of_measurement: hours
Adicione isso ao seu Lovelace (dentro de uma view):
  - cards:
      - entities:
          - entity: sensor.last_boot
            icon: 'mdi:clock'
        show_header_toggle: false
        title: Raspberry Pi4
        type: entities
      - cards:
          - color_thresholds:
              - color: '#bf4040'
                to: 100
              - color: '#ffde00'
                to: 49
              - color: '#40bf40'
                to: 9
            entities:
              - entity: sensor.processor_use
                index: 0
                name: CPU - Uso
            icon: 'mdi:memory'
            type: 'custom:mini-graph-card'
          - color_thresholds:
              - color: '#bf4040'
                to: 100
              - color: '#ffde00'
                to: 55
              - color: '#40bf40'
                to: 50
            decimals: 0
            entities:
              - entity: sensor.cpu_temperature
                index: 0
                name: CPU - Temperatura
        type: horizontal-stack
      - cards:
          - aspect_ratio: 1/1
            custom_fields:
              cpu: |
                  return `<ha-icon
                    icon="mdi:cpu-64-bit"
                    style="width: 12px; height: 12px; color: var(--paper-item-icon-active-color);">
                    </ha-icon><span>  CPU: <span style="color: var(--text-color-sensor);">${states['sensor.processor_use'].state}%</span></span>`
              ram: |
                  return `<ha-icon
                    icon="mdi:memory"
                    </ha-icon><span>  RAM: <span style="color: var(--text-color-sensor);">${states['sensor.memory_use_percent'].state}%</span></span>`
              ssd: |
                  return `<ha-icon
                    icon="mdi:harddisk"
                    </ha-icon><span>  SD: <span style="color: var(--text-color-sensor);">${states['sensor.disk_use_percent_home'].state}%</span></span>`
              temp: |
                  return `<ha-icon
                    icon="mdi:thermometer"
                    style="width: 18px; height: 18px; color: var(--text-color-sensor);">
                    </ha-icon><span>${entity.state}°C</span>`
            icon: 'mdi:desktop-tower-monitor'
            name: Raspberry Pi4 4gb
            styles:
              card:
                - padding: 10%
                - font-size: 12px
                - text-shadow: 0px 0px 0px black
                - text-transform: uppercase
                - font-variant: small-caps
              custom_fields:
                cpu:
                  - padding-bottom: 2px
                  - align-self: middle
                  - justify-self: start
                  - '--text-color-sensor': >-
                      [[[ if (states["sensor.processor_use"].state > 5)
                      return "red"; ]]]
                ram:
                      [[[ if (states["sensor.memory_use_percent"].state >
                      80) return "red"; ]]]
                ssd:
                      [[[ if (states["sensor.disk_use_percent_home"].state >
                temp:
                  - align-self: start
                  - justify-self: end
                      [[[ if (entity.state < 50) return 'green'; if
                      (entity.state >= 60 && entity.state < 80) return
                      'orange'; else return 'red'; ]]]
              grid:
                - grid-template-areas: '"i temp" "n n" "cpu cpu" "ram ram" "ssd ssd"'
              icon:
                - color: |
                      if (entity.state >= 60 && entity.state < 80) return 'orange';
                      else return 'red';
                - width: 70%
                - margin-top: '-10%'
              img_cell:
                - justify-content: start
                - align-items: start
                - margin: none
              name:
                - font-weight: bold
                - font-size: 12px
                - color: white
                - padding-bottom: 4px
            tap_action:
              action: navigate
              navigation_path: '#system'
            type: 'custom:button-card'
          - entity: sensor.speedtest_download
            type: gauge
            unit: ' '
          - entity: sensor.speedtest_upload
            type: gauge
            unit: ' '
      - align: split
        animation: auto
        attribute: false
        card_style: false
        charge_entity: false
        columns: 1
        decimal: 0
        delay: 5000
        direction: right
        entities:
          - entity: sensor.disk_use_percent_home
            icon: 'mdi:harddisk'
            severity:
              - color: '#40bf40'
                value: 10
              - color: '#ffde00'
                value: 50
              - color: '#bf4040'
                value: 100
            title: HDD
          - entity: sensor.memory_use_percent
            icon: 'mdi:memory'
            severity:
              - color: '#40bf40'
                value: 0
              - color: '#ffde00'
                value: 50
              - color: '#bf4040'
                value: 100
            title: RAM
        entity_config: true
        height: 40px
        icon: false
        icon_position: 'off'
        icon_style:
          filter: none
          height: 34px
          width: 34px
        indicator: auto
        limit_value: false
        max: 100
        min: 0
        minmax_style: false
        padding: 5px
        positions:
          icon: 'off'
          indicator: 'off'
          title: outside
        rounding: 5px
        saturation: 50%
        severity:
          - color: '#bf4040'
            to: 100
          - color: '#ffde00'
            to: 49
          - color: '#40bf40'
            to: 19
        show_icon: true
        show_minmax: false
        show_value: true
        speed: 1000
        style: |-
          bar-card-current, bar-card-backgroundbar {
            border-radius: 20px;
          bar-card-value {
            margin-right: auto;
        tap_action: info
        target: false
        title: false
        title_position: inside
        title_style:
          color: '#00000'
          font-weight: normal
          text-shadow: none
        type: 'custom:bar-card'
        unit_of_measurement: false
        value_style:
          color: '#00000'
          font-size: 18px
          font-weight: normal
          text-shadow: none
        visibility: false
        width: 100%
    type: 'custom:vertical-stack-in-card'
Parabéns pelo tutorial,muito bem explicado!!!
Ótimo tutorial, mas não esta funcionando no meu home assistant, acredito que a versão do meu lovelece seja diferente. Estou usando a vesão mais atualizada.
Por favor podeiria atualizar a parte que vc diz “Adicione isso ao seu Lovelace”?
Te agradeço muito por toda a ajuda e por compartilhar seu conhecimento no home assistant.
grande abraço e muito obrigado.
Eu também tentei nesse final de semana, e, depois de muita briga, o máximo que consegui foi isso:
Mas serviu de inspiração, e comecei a trabalhar na minha tela de controle do RPi, nada tão rebuscado como o seu exemplo, mas estou tendo algum retorno visual.
Já está dando para o gasto :smile:
Boa noite.
Para ajudar os amigos fiz algumas alterações no código do alexspires para o cartão funcionar na atual versão do lovelace.
Não ficou exatamente igual mas ficou bem parecido.
Segue o codigo do Leandro nas mensagens logo abaixo.
Valeu. Vou tentar no final de semana, ou antes se houver lockdown por aqui. :thinking:
Aqui tem barreira em tudo quanto é lugar, ninguém passa.
Você é de onde ? Aqui no RJ será a partir de sexta, mas ainda não está confirmado. Pelo menos que eu saiba com certeza.
consegui colocar a foto na mensagem a cima
Está muito legal. Certamente já tenho o que fazer no fds.
Grande abraço, boa semana para vc
Sou de Cabo Frio
Vou tentar configurar minha camera de segurança no home assistant hoje ainda.
Boa noite pessoal,
Segue minha adaptação deste código para a forma atual:
type: vertical-stack
cards:
  - type: entities
    entities:
        state_color: false
    state_color: true
    title: Raspberry Pi
  - type: horizontal-stack
    cards:
      - type: 'custom:mini-graph-card'
        entities:
          - sensor.processor_use_percent
        name: CPU - Uso
        line_color: cyan
        line_width: 8
        font_size: 70
        icon: 'mdi:server'
        show_label: true
        entities:
          - sensor.cpu_temperature
        index: 1
        line_color: cyan
        line_width: 8
        font_size: 70
        show_labels: true
    cards:
      - type: 'custom:button-card'
        aspect_ratio: 1/1
        name: Rasp Pi3 16gb
        styles:
          card:
            - border-radius: 10%
            - padding: 10%
            - color: white
            - font-size: 10px
            - text-shadow: 0px 0px 5px black
            - text-transform: captalize
          grid:
            - grid-template-areas: '"i temp" "n n" "cpu cpu" "ram ram" "sd sd"'
            - grid-template-columns: 1fr 1fr
            - grid-template-rows: 1fr min-content min-content min-content min-content
          name:
            - font-weight: bold
            - font-size: 13px
            - color: white
          img_cell:
            - margin: none
          icon:
            - color: cyan
            - width: 70%
          custom_fields:
            temp:
              - align-self: start
              - justify-self: end
            cpu:
                  [[[ if (states["sensor.processor_use_percent"].state > 80)
                  return "red"; ]]]
            ram:
                  [[[ if (states["sensor.memory_use_percent"].state > 80) return
                  "red"; ]]]
            sd:
                  [[[ if (states["sensor.disk_use_percent_home"].state > 80)
                  return "red"; ]]]
        custom_fields:
          temp: |
              return `<ha-icon
                style="width: 12px; height: 12px; color: cyan;">
          cpu: |
              return `<ha-icon
                icon="mdi:server"
                </ha-icon><span>CPU: <span style="color: var(--text-color-sensor);">${states['sensor.processor_use_percent'].state}%</span></span>`
          ram: |
              return `<ha-icon
                icon="mdi:memory"
                </ha-icon><span>RAM: <span style="color: var(--text-color-sensor);">${states['sensor.memory_use_percent'].state}%</span></span>`
          sd: |
              return `<ha-icon
                icon="mdi:harddisk"
                </ha-icon><span>SD: <span style="color: var(--text-color-sensor);">${states['sensor.disk_use_percent_home'].state}%</span></span>`
        type: gauge
        unit: ' '
        severity:
          green: 0
          yellow: 45
          red: 85
        type: gauge
        unit: ' '
        severity:
          green: 0
          yellow: 45
          red: 85
  - align: split
    animation: auto
    attribute: false
    card_style: false
    columns: 1
    decimal: 0
    delay: 5000
    direction: right
    entities:
        severity:
          - color: '#40bf40'
            value: 10
          - color: '#ffde00'
            value: 50
          - color: '#bf4040'
            value: 100
        icon: 'mdi:memory'
        severity:
          - color: '#40bf40'
            value: 0
          - color: '#ffde00'
            value: 50
          - color: '#bf4040'
            value: 100
    entity_config: true
    height: 40px
    icon: false
    icon_style:
      filter: none
      height: 34px
      width: 34px
    indicator: auto
    limit_value: false
    max: 100
    min: 0
    minmax_style: false
    padding: 5px
    positions:
      icon: 'off'
      indicator: 'off'
      title: outside
    rounding: 5px
    saturation: 50%
    severity:
      - color: '#00ffff'
        to: 100
      - color: '#00ffff'
        to: 49
      - color: '#40bf40'
        to: 19
    show_icon: true
    show_minmax: false
    show_value: true
    speed: 1000
    style: |-
      bar-card-value {
        margin-right: auto;
    tap_action: info
    target: false
    title: false
    title_style:
      color: '#00ffff'
      font-weight: normal
      text-shadow: none
    value_style:
      color: '#00ffff'
      font-size: 18px
      font-weight: normal
      text-shadow: none
      visibility: false
      width: 100%
Boa Leandro.
Não sei como colocar o código aqui no grupo.
Muito obrigado por sua ajuda.
Rapaz nem me fale, apanhei tanto para fazer funcionar e depois apanhei mais um pouco para colocar o código aqui kkkkkkk
Agora aprendi que é só colocar entre “[code]””[\code]” sem aspas que da certo
Eu também fiz uma alteração e ficou dessa maneira.
Valeu…
Oi @alexspires . Como vc tá usando o DNSIP? Estou querendo ver o meu IP externo e me notificar quando ele muda. Vc fez algo semelhante? Eu tentei usar e não ta me retornando o IP.
